996 : 1997-2005 38
964 : 1989-1993 4
Boxster : 1997- 18
Cayman : 2005- 10
limpetminer
PostPosted: Wed Aug 30, 2017 5:15 pm    Post subject: Boxster brake fluid check Reply with quote
Just attempted to check brake fluid condition but don't seem to be able to remove the filter in top of reservoir is there some trick to this or am I being thick ??
ragpicker
PostPosted: Wed Aug 30, 2017 8:07 pm    Post subject: Reply with quote
Just twist it off..
Can be stuck though so the more smaller biceped amongst us may need to use an adjustable plumbers wrench on it to get enough 'purchase'..
PostPosted: Wed Aug 30, 2017 8:17 pm    Post subject: Reply with quote
I cant remember cause its late .. im tired .. but is there a filter under the cap once removed ?
I know there is on some models and it would stop you getting a tester into the resevoir .. if so its not really removable but a bit of levering with a screwdriver would probably do it.
Personnely i would just say a brake fluid change should be done every 2 years ..
Also seeing as i nearly fell asleep writeing this im off .. laters Very Happy
ragpicker
PostPosted: Wed Aug 30, 2017 8:19 pm    Post subject: Reply with quote
Yes mate, there is. A little mesh filter but it comes out with a flat-head screwy.
