996 : 1997-2005 41
993 : 1993-1998 8
964 : 1989-1993 6
Early 911 : 1964-1977 2
Classic : 1950-1965 1
Boxster : 1997- 10
Cayman : 2005- 17
Soondra
PostPosted: Sat Aug 12, 2017 8:55 pm    Post subject: 996 Targa rear seats wet Reply with quote
My Porsche 911 996 Targa (2002) has had an increasingly bad problem of wet rear seats and carpets. It got so bad that my rear left seat was permanently soaked (damaging the leather).
I searched the forums for solutions and couldn't quite work out the issue. But I think it's a common problem and (fingers crossed) I think I worked it out. I did take out a lot of carpets and panels (but I didn't need to).
The problem is a blockage (dirt and rotten leaves I think) in drainage pipe 1 (see the attached diagram). You access the pipe relatively easily by removing the loose carpeted panel at the back of the hatchback area (see photo). The pipe is just at the end of the roof rail.
If you have wet seats in your Targa and this is the cause, remove the rear carpeted panel and get someone to pour water on the roof. If the pipe is blocked, there will be quite a bit of water pouring out (it then spills over the parcel shelf, gets onto the seat area, and then spills onto the carpet).
If this is the problem, pull the pipe off the back and blow it out with a compressor. I unwisely sucked on the pipe, to find a mouthful of sludge.
Anyway, a potentially very expensive (there's a lot of electronics, leather and carpet to get damaged) problem sorted quite easily. I hope this helps.
Drainage pipe 1 behind carpeted rear panel
 Filesize:  122.84 KB
 Viewed:  636 Time(s)
Drain diagram (996 targa)
 Filesize:  88.26 KB
 Viewed:  636 Time(s)
Demort
PostPosted: Sun Aug 13, 2017 4:06 pm    Post subject: Reply with quote
Some more info on the roofs can also be found here ..
http://911uk.com/viewtopic.php?t=116450
At an Indy these days !
infrasilver
Fast & Furious
Fast & Furious
2001 Porsche 996 Targa
PostPosted: Sun Aug 13, 2017 5:27 pm    Post subject: Reply with quote
My issue with water ingress in the same area as your was the centre pipe blocked above the B pillar, the water was running down the roof runner to the rear, this drain pipe also seems to shrink over time.
