997 : 2004- 64
964 : 1989-1993 4
Boxster : 1997- 19
Cayman : 2005- 10
Cayenne : 2003- 4
Macan : 2014- 1
Tomson
PostPosted: Thu Aug 03, 2017 9:12 am    Post subject: Knock Sensor Wiring Reply with quote
Hello,
I am after some advice/help please, the wiring to my knock sensor has broken at the connector end. My mechnic has asked whether I can source a new connector and some tails so he can mend it.
Porsche want to sell me an entire loom!
There are some similar looking connectors on eBay as the sensor is OEM for quite a few different manufacturers.
Knock sensor wiring issues seem quite common has anyone any experience of the right connector for the Bosch sensor, or a 3rd party repair kit?
My car is an 02 C4S if it helps?
cheers,
Tom
alex yates
PostPosted: Thu Aug 03, 2017 9:51 am    Post subject: Reply with quote
Can you not just fix your connector? I'd be slicing it open with a scalpel and re-soldering the wires back on.
Tomson
PostPosted: Thu Aug 03, 2017 10:00 am    Post subject: Reply with quote
My mechanics are trying to do it with everything still in situ, I think
It's a little cramped in there!
Although it might come to that.
I have someone on PCGB breaking a Boxster who might be able to cut me some decent tails.
Tom
infrasilver
Fast & Furious
Fast & Furious
2001 Porsche 996 Targa
PostPosted: Thu Aug 03, 2017 3:39 pm    Post subject: Reply with quote
I would guess the connector is fairly generic for various knock sensors but finding the correct one would be hard, what I would do is what you have said, get a used loom or end cut off and solder in. The loom is one piece and OPC don't sell the connectors separately.
Harv
PostPosted: Thu Aug 03, 2017 5:16 pm    Post subject: Reply with quote
All the sensor plugs are generic and I had a similar issue with a smashed cam position sensor plug on bank 2
I cut it off, cleaned it up in petrol and carefully examined it which got a part number and with that info found said plug on Amazon.com for £2.50 delivered.
Hope this helps Thumb
