996 : 1997-2005 42
Boxster : 1997- 13
Cayman : 2005- 12
Macan : 2014- 0
Scholester
PostPosted: Sat Jul 29, 2017 9:17 pm    Post subject: Tandem pump cover swap - minor detail Reply with quote
I am still working on my car (work has been extremely busy) and part of my list of bits is a new Tandem Pump Cover.
The existing cover was in fact in pretty good order with only minor/moderate rusting but being swapped out it is for one of the excellent quality ACP covers (not over-cover).
The question is, when I removed my old cover, the blade and two end bearings slipped out with it. I get how it sits together and it may be a little tricky in ensuring that the new cover slips over the blade/bearings without them shifting (I was thinking elastic band until cover is partially on before sniping this away).
The actual question is whether there is any significance of the tiny little slot on one side of the blade as the other side is marked with a blue circle. Does this micro-slot engage with anything within the slotted pump shaft?
I will try and upload some photos which may help explain a whole lot better. Photos may follow as not uploading in this post.
997.1 Turbo Coupe, manual, black/black. 29k miles under its belt.
Scholester
PostPosted: Sat Jul 29, 2017 9:21 pm    Post subject: Reply with quote
Second time lucky?
 Filesize:  981.77 KB
 Viewed:  5135 Time(s)
 Filesize:  1.07 MB
Scholester
PostPosted: Sat Jul 29, 2017 9:22 pm    Post subject: Reply with quote
New cover
 Filesize:  1.15 MB
 Viewed:  5136 Time(s)
symoonbeam
PostPosted: Sun Jul 30, 2017 6:28 am    Post subject: Reply with quote
Scholester
FYI - you might find that you have an issue following fitting of the ACP cover with getting any vacuum generated.
I purchased one of these covers and had it fitted at 9e - although the cover was well made, there was no vacuum following its fitment. Re-fitting the original cover solved the problem.
Apparently this is a common problem.
I gather it is more to do with the way the original vanes and covers have bedded together, rather than an issue with the replacement cover itself - if the new cover does not provide any vacuum the only options are to either refit the original cover or replace the entire pump.
997.1 Turbo
TechArt "sport" exhaust system
TPC DSC Suspension Module
DO88 Intercoolers and Inlet Hoses
Cobb Access Stage 2 Tune
Carbon Bonnet
Scholester
PostPosted: Sun Jul 30, 2017 11:00 pm    Post subject: Reply with quote
symoonbeam wrote:
Scholester
Thanks for this Sy.
Not being a particularly technical bod', how will this manifest itself in what I will notice/ what will not happen, that should happen!? Excuse my ignorance but I have never taken the trouble to understand what the pump actually does!
Any more contributors on the specific orientation of the blade itself with blue circle v small slotted grove?
symoonbeam
PostPosted: Mon Jul 31, 2017 8:35 am    Post subject: Reply with quote
The tandem pump provides vacuum pressure to assist the brake and (I think) clutch circuits so you will find that you have a very hard brake pedal and that it doesn't actually apply the brakes to any degree!!
997.1 Turbo
Carbon Bonnet
Scholester
PostPosted: Mon Jul 31, 2017 4:28 pm    Post subject: Reply with quote
Quite important to get this right then!
Any views on the small slot on one side of the blade that holds the two outer bearings?
PostPosted: Mon Jul 31, 2017 6:08 pm    Post subject: Reply with quote
Im the first to admit ive never removed a cover from one of these .. ive always just changed the unit ..
Are you sure that part in the cover doesnt fit in the pump side as there are no locations for it in the cover and it REALLY looks to me like its part of the pump ..
Picture of the pump side if posible please .
Scholester
PostPosted: Tue Aug 01, 2017 11:08 am    Post subject: Reply with quote
 Filesize:  1.24 MB
 Viewed:  4732 Time(s)
 Filesize:  1.01 MB
 Filesize:  1.03 MB
Scholester
PostPosted: Tue Aug 01, 2017 11:11 am    Post subject: Reply with quote
Yes Demort, locates on the pump side then the cover slips over. Will be fun keeping the three items together whist pushing the cover in place but a rubber band may help initially before fully pushing the cover home.
PostPosted: Tue Aug 01, 2017 6:23 pm    Post subject: Reply with quote
Excellent .. thanks for that as ive never seen the inside of one before .
Probably teaching you to suck eggs here as you are doing what i havent but if you turn the engine over by hand would the pump bars end up sideways and stay in place a little easier to get the cover on Dont know
I promise that the next time i change one ill strip it and see how it all works .. ill know what im talking about then Smile
Scholester
PostPosted: Tue Aug 01, 2017 7:37 pm    Post subject: Reply with quote
Thanks again Demort.
I am good friends with The Finn on here and he changed his cover with little problem and did not experience any of the issues that Sy has raised with not getting a vacumm.
The fitting itself is not the problem, it was really whether the oriapentation of the little slot on the blade made any difference but I think it's down to me to experiment further.
Stever845
2005 Porsche 997 Carrera 2S
PostPosted: Tue Aug 01, 2017 8:51 pm    Post subject: Reply with quote
I put one of these on mine about a 1000 miles ago with no issues so far .
http://911uk.com/viewtopic.php?t=119488&start=0&postdays=0&postorder=asc&highlight=
997.1 C2S Atlas Grey,Manual,sport chrono,pasm,
Mini Cooper S JCW
Ducati Panigale 1199S
Scholester
PostPosted: Wed Aug 02, 2017 3:38 pm    Post subject: Reply with quote
That is good news. Hopefully mine too will work swimmingly.
I reckon another couple of shifts in the garage (may not be until late August) will see all of the work done and I will complete a little write up on what I achieved as I have taken many photos for reference.
Thanks all Thumb
Nik
PostPosted: Sun Aug 06, 2017 3:48 pm    Post subject: Reply with quote
Sorry for the ignorant question but is this tandem pump cover an issue for 997.1 as well as 997.2 ?
Also, the ACP cover seems a little pricey at £175?
Scholester
PostPosted: Tue Aug 08, 2017 5:36 am    Post subject: Reply with quote
Hi Nik,
In all honesty, I am not sure what set-up the DFI engine (.2) has with regards to the Pump. I can however tell you that .1 and .1T both have the Pierburg pump with poor quality cover that will rust through in time and should be monitored often and closely. Original replacement Pierburg covers are not available so it's either a new pump or something like this ACP option which is half the price of a new pump.
Regards,
systech1
PostPosted: Tue Aug 08, 2017 6:37 am    Post subject: Reply with quote
Also provides vacuum for the hemholz resonator in the airbox and PSE switchover (if you have this option).
Long time Porsche fan. Previous cars include 911T 2.2, 911E 2.2, Carrera 3.0, 986 Boxster S. Current car is 997.2S Manual (with PSE, H&S Backbox bypass, Sports Chrono, SSK, Carrera Sports wheels, Sport Design steering wheel etc.)
DucatiRob
PostPosted: Tue Aug 08, 2017 7:47 am    Post subject: Reply with quote
Hi Nik,
Regards,
Worth noting that Autodoc sell the Pierburg pump at much less than Porsche, around £250, they are always having sales too, this week it was 17% off everything!!
I read a lot about the various covers available for the standard pump and there are very mixed reports, some ok and some not. The cover itself is a bearing surface for the blade, so any inaccuracy here is going to be a problem, particularly as the internals will have bedded in and worn to the old cover!
Mercedes CLK DD
Ducati 996
Nik
PostPosted: Tue Aug 08, 2017 3:43 pm    Post subject: Reply with quote
Scholester wrote:
Hi Nik,
Regards,
Many thanks. Will do some more digging to see if I have the same on the 997.2.
I was just thinking that £175 is a lost for a cover, when the new pump can be bought for £230 as mentioned above.
Scholester
PostPosted: Wed Aug 09, 2017 1:45 am    Post subject: Reply with quote
DucatiRob wrote:
Hi Nik,
Regards,
The original cover looks like a cheap pressed piece of mild steel to me so not sure that the milled ACP cover can offer less in the way of tolerances. The ACP comes with QC certification so here's hoping!
