996 : 1997-2005 43
Boxster : 1997- 13
Cayman : 2005- 12
Macan : 2014- 0
rus_987
PostPosted: Mon Jul 17, 2017 10:09 am    Post subject: 987 front fog lights and PSM question Reply with quote
Hi all,
Wondering if you can shed some light on a few issues that I have with my 987 05 2.7 Boxster.
1) The front fog lights do not work ... I think I should check the fuse first before replacing the bulbs, but unfortunately I do not have a fuse diagram...I googled it, and found a diagram but could not locate which one is the front foglight fuse on the halogen version 987...could someone tell me which 1 it is please?
2) The PSM failure light comes on every time after about 20 minutes of driving on the motorway at speeds of more than 60mph... it cancels itself when I switch off and re-start the engine, and never comes on around town. What could this be?
Thanks for your help![/list]
PostPosted: Mon Jul 17, 2017 6:37 pm    Post subject: Reply with quote
If you pull the fuse cover off then there should be a booklet listing what all the fuses are for on the cover .
I take it the headlight switch does have the symbol for front and rear fog lights on it ?
Day runners or home lights spring to mind if not .
I think but not sure that there are options for lights in the pcm .. thats more an owners thing than a mechanics as i dont really delve into pcm options Smile
For the fault then it will need a code reader and the code read out as there are many things it could be im afraid .
A guess would be a speed sensor on one of the wheels dropping out at speed due to a weak signal ..
rus_987
PostPosted: Tue Jul 18, 2017 1:20 pm    Post subject: Reply with quote
Thank you for the reply...unfortunately I do not have the booklet, and although I think I found a copy online, I cannot read it (stupid). Would just help to know exactly which fuse to check Question
PostPosted: Wed Jul 19, 2017 7:17 pm    Post subject: Reply with quote
Try this ..
Also does the head light switch have the x2 symbols for front and rear fog lights ?
Its just im wondering if they are the home lights .. switch onto home then lock the car and see what works .
If they are fog lights then youll need a tester as its a control unit fault i expect .. possibly codeing .. but always worth checking if theres a fuse first Smile
 Filesize:  44.1 KB
 Viewed:  4154 Time(s)
rus_987
PostPosted: Thu Jul 20, 2017 4:03 pm    Post subject: Reply with quote
Demort wrote:
Try this ..
So would I be correct in saying that the fuse should be A5?
It does have the x 2 for the front and rear fog lights on the switch, and also it has home (which doesn't work either)...hmm I just realised - based on this it has to be either the bulbs or the fuse...can't be the switch
PostPosted: Thu Jul 20, 2017 6:27 pm    Post subject: Reply with quote
Fuse would be A 7 , you also have C7 but other things wont work if its that one .
Home lights not working And front fog lights , check the fuse and the bulbs as it may be simple but i think this is going to end up a little bit more involved , the control unit responsable is the front end control unit .
A vehicle handover useing a tester would be the next step if its not fuse or both bulbs .
rus_987
PostPosted: Tue Jul 25, 2017 8:49 am    Post subject: Reply with quote
OK I checked A7...seems fine, will check bulbs...and then take it from there.
Thanks for the help so far Smile
isysman
PostPosted: Tue Jul 25, 2017 8:58 am    Post subject: Reply with quote
Dermot would it not be A3&4? What he is calling fog lights maybe his side lights?
911 GT2RS Build - 981 Boxster S
rus_987
PostPosted: Tue Jul 25, 2017 9:12 am    Post subject: Reply with quote
OK you know you have the main headlight housing with the main beam and dipped beam...and then you have the white rectangular housing on the bumper below the headlight which houses the fog light and the sidelight...the sidelight bulbs work fine, but the fog light bulbs don't.
I have the fog light option on the control panel (i.e. turn the switch to side light or beam position and pull it out, and a green foglight light comes on the dash next to the switch)...however the fog lights don't work.
I have tried putting the switch in the "home" position...from my understanding this should activate the fog lights once you press the "unlock" on the remote...again - no luck.
isysman
PostPosted: Tue Jul 25, 2017 9:42 am    Post subject: Reply with quote
Ok that clears it up. Yes they are your fog lights. To turn them on you pull the switch once in the lights on position.
rus_987
PostPosted: Tue Jul 25, 2017 9:47 am    Post subject: Reply with quote
Yeah, I read somewhere that you might need to program them to work, but I guess if it has the home option and the fog light switch then they should work...otherwise no point putting them there Dont know
PostPosted: Tue Jul 25, 2017 6:43 pm    Post subject: Reply with quote
Just to clarify things as im getting a little confused now lol .. is your headlight switch the same as the image below .. ie does it have both symbols on the left side of the switch .
If it does then its a codeing fault , blown bulbs or a possible wiring fault .. ie not plugged in .
Im no expert on function operation but the home setting is for when you lock the car so you have illumination when you walk away from the car .. at least thats what i thought so try that please.
Also if you have a PCM fitted then hit the set button and see if theres an option for day runners .
I blame Porsche .. if they fitted the same stuff to every vehicle then i would know what i was talking about
Razz
This stuff is just sooo much easier when i have the car to look at sigh
 Filesize:  9.56 KB
 Viewed:  3903 Time(s)
rus_987
PostPosted: Tue Jul 25, 2017 6:49 pm    Post subject: Reply with quote
Razz
Yes sir that's the exact same switch that I have. Once I change the bulbs if it still don't work I might have to bring it to you.
PostPosted: Tue Jul 25, 2017 6:52 pm    Post subject: Reply with quote
lol .. bless you .. ok im happy now .. they should work so start with the bulbs Smile
