Headlight removal problems
edh
25 Apr 2009
37
Looking for clues here....
I managed to change one headlamp easily enough, a bit of silicon spray on the runners helped the replacement slide in smoothly
The second won't budge - using the removal tool to turn the lever just results in a loud click but no movement of the headlamp
Obviously this is also a problem if I want to change bulbs..
Can I get at it from the wheel arch if I remove the liner?
Any other tips?
Ed
Yes, you can :thumb: May be the only option if it's stuck there.. Remove the liner and you'll be able to push it from the back of the unit
Sorted - thanks :)
How many different types of fastener do they use on those arch liners! - I hate those trim clips...
124,594
1,441,921
49,026
WilmslowSi
