Brake dust / heat shield
mun802
5 Apr 2008
143
My rear brake dust heat shield is rattling around from couple of sheared bolts from what i can see.
Tried google without success , but was wondering do you have to remove caliper etc to change. Cant make out which way bolt heads are orientated without jacking up and removing wheel.
I'd imagine it will be caliper and disc off
You need to remove the disc to get at these, the holes are blind tapped from the outside.
When removing/refitting the caliper pay particular attention to the caliper bolt torque settings, they are low and that way for a reason as the bolts have a tendency to strip the threads in the carrier, usually down to them being over tightened or cross threaded. - If this happens its not the end of the world but you will need a heli-coil kit to rectify.
Thanks guys for your help. Bit of a ball ache of a job then and £££'s too no doubt :eek:
Its not a difficult job, a little time consuming but not difficult.
The only area of concern is the caliper bolts but in general its a walk in the park.
I actually removed my dust shields to help with brake cooling, I have suffered no adverse effects and to my knowledge nor have others that have done the same.
124,555
1,441,481
48,969
Stulees65
