997 : 2004- 71
996 : 1997-2005 48
964 : 1989-1993 4
Boxster : 1997- 18
Cayman : 2005- 15
Cayenne : 2003- 9
Macan : 2014- 1
912-914-924-928-944-968 3
johne
PostPosted: Sat Jul 08, 2017 8:00 am    Post subject: gearbox rebuild Reply with quote
this is probably be my next job in line first and second gear are a bit notchy .may be the traits of the car .but while doing this ill probably think about a lwt flywheel and clutch .I need some advice really .who to use and what other things to get done. not being to mechanicly minded can any one tell the difference with a limited slip diff . I plan to do the odd trackday . I can always seem to bank on good advice on the forum I live in the Essex area but could travel for some one who works on these gearboxes .also how about the clutch from steve weiner
PostPosted: Sat Jul 08, 2017 8:31 am    Post subject: Reply with quote
Clinchy is the man to answer this as he had his 993 box rebuilt and dabbles in the occasional track day Thumb
I think there is a thread on it somewhere but IIRC the gearbox rebuild wasn't cheap what
madge
PostPosted: Sat Jul 08, 2017 10:20 am    Post subject: Reply with quote
I'll be interested to follow your progress with this johne.
I really struggle with the gear change between first and second on mine, even when fully warmed. If I'm being slightly aggressive with the revs when pulling away (which is my preference because I like the noise) I get a rather large 'clunk' going into second and sometimes it feels like it almost jumps out of first gear when I make the change. I have to nurse it to avoid the issue and can't really put my foot down until in second, and where's the fun in that?
With this being my first 993 I don't know whether this is just a characteristic or whether my gearbox needs a rebuild. I spoke to my indy about it last time the car was in and they didn't seem overly concerned. They said you could open it up and might not see any glaring problems and, commendably, didn't seem overly keen to spend my money for me. I had the gearbox oil changed but that hasn't helped.
I've got the G50 gearbox, maybe they're all like this. Dont know I could easily live with it but it does spoil the enjoyment of the drive somewhat.
Current: 993 Carrera Coupé, Manual, Varioram
Previous: 987 Cayman S
ras62
PostPosted: Sat Jul 08, 2017 10:58 am    Post subject: Reply with quote
Worn engine mounts make a significant difference to shaft quality so thats the first place to look. A simple oil change can also see shift quality increase.
As for the installation of a LWF I would try before you buy as they aren't to everyones liking. The noise especially doesnt sit well with some owners but the added response of the engine in the lower gears more than outweighs the downsides imo.
Endoman
PostPosted: Sat Jul 08, 2017 3:39 pm    Post subject: Reply with quote
I would try an oil change before anything else and a clutch bleed. Usual check for LSD is jack up rear and turn one wheel if opposite turns in opposite direction no lsd, if same lsd present. LWF is a great performance mod but the chatter especially when warmed up can be annoying and the engine may be prone to stalling. I love my LWF and had the 1st to second stiffness 'til I changed the oil, the thump on releasing first is usually clutch not releasing fully.
911smark
PostPosted: Sun Jul 09, 2017 7:36 am    Post subject: Gear Box rebuild Reply with quote
I'd use Neil Bainbridge, BS motorsport, Wescott, nr Aylesbury, Bucks, Top bloke, knows air cooled cars like nobody else.
Cameltoe & Heel
PostPosted: Mon Jul 10, 2017 7:40 am    Post subject: Reply with quote
My box is currently in with Unit11 in Warrington for rebuild, car done 104k miles and it appears the diff orbital gears are toast, clearly been like that for a while. Would suggest previous owner hasn't changed the oil to cause wear like that. Dont know
Will change bearings and syncros etc.
Trev
madge
PostPosted: Mon Jul 10, 2017 11:55 am    Post subject: Reply with quote
Trev
What were your symptons Trev?
Have Unit11 given you an estimate for the cost of the work? Just a ballpark figure would be really useful.
ballcock
1996 Porsche 993 Carrera 2
PostPosted: Mon Jul 10, 2017 2:21 pm    Post subject: Reply with quote
For the OP's symptoms , would anyone recommend a transmission mount change? (assuming the engine mounts are done)
'83 W460 LWB G Wagen updated with OM602 engine and 6 speed 'box ...My daily driver
Ex. '99 996 C2 manual coupe.
Cameltoe & Heel
PostPosted: Mon Jul 10, 2017 3:37 pm    Post subject: Reply with quote
Trev
No symptoms as I bought the car damaged so no chance to drive it.
Essentially the gearbox requires further investigation before an exact price can be determined.
Eeek.
johne
PostPosted: Mon Jul 10, 2017 9:46 pm    Post subject: gearbox rebuild Reply with quote
i thought changing the gearbox mount on a carrera 2 was difficult .I already have RS engine mounts and have changed the gearbox oil with motul 600. I'm having a check strap done this weekend by erdell in harlow .so I might go with the short shift kit next to see if there is any play there .seems like that is the cheapest thing next .and if that dosent improve it the gearbox rebuild next. I remember someone saying on here you can spend £10,000 on a 993 quite easily
wozy
PostPosted: Tue Jul 11, 2017 2:50 pm    Post subject: Reply with quote
As others have already stated, change the engine mounts before anything else. Mine was night and day better ref the gearchange between 1st & 2nd afer I replaced mine. You may as well go C4 mounts, less flex and a lot cheaper, nice halfway house between C2 and RS. Mine have been on four years and absolutly no issues.
Ref the 'bang' someone is getting whilst changing gear, I'd say that was a DMF on the way out rather than a gearbox issue ..... loits of 993s suffer from this. Thumb
Porsche Cars of Great Britain launched the 993 in the UK in early December 1993 registering 12 x UK cars on the 6th & 7th of that month; mine is one of them.
993 C2. MBM. C4 mounts, RSRs, RS Short shifter. RS steering wheel. FSDs & M033s
Previous 2.7S, 3.2, 964 and 968CS
madalaa
2009 Porsche Boxster (987)
PostPosted: Tue Jul 11, 2017 3:41 pm    Post subject: Reply with quote
...... but normally not in one straight hit ....... usually over a few years is about right unless you are particularly unlucky or OCD fussy ...... lol ...... Wink
johne
PostPosted: Tue Jul 11, 2017 8:26 pm    Post subject: gearbox rebuild Reply with quote
johne
PostPosted: Tue Jul 11, 2017 8:27 pm    Post subject: Reply with quote
madge
PostPosted: Thu Jul 13, 2017 5:49 pm    Post subject: Reply with quote
Thanks for that interesting suggestion wozy. OK, I'll admit that I had to go and look-up DMF.... Embarassed . I'm surprised that my indy didn't float that as a possible cause of the issue.
Unless it fails completely is it something that would only make sense to change when fitting a new clutch?
Has anyone else suffered from the 'bang' between gear changes and solved it with a change of the flywheel?
future
PostPosted: Mon Jul 17, 2017 2:30 am    Post subject: Reply with quote
http://www.sportsandclassic.com/index.php?page=services_gearbox_rebuilds
... end of. Give them a call Thumb
LondonRob
PostPosted: Mon Jul 17, 2017 7:23 am    Post subject: Reply with quote
I received the same advice when I had problems with second gear changes when I first bought my car. Phoned these people up (even though I'm not local), discussed over the phone and their recommendation was change to C4 engine mounts initially. This definitely improved the change. I subsequently installed a short shift kit and I think this has also helped. Well worth a phone call - even though it would be a pain logistically for me due to distance I'd strongly consider getting my gear box to these people if it did actually need a rebuild.
wozy
PostPosted: Mon Jul 17, 2017 11:26 am    Post subject: Reply with quote
A couple of indies didn't pick up on it for me either. Took it to autofarm and they diagnosed it within driving the car 30 seconds. I've had mixed replies whether I should replace it, one said I should asap, the other who is a far more a practical kind of fella (and loves aircooled) said that he believed it ok to leave as is until clutch change. So far I've driven 30k miles with it like it is. Mind you it won't be long till I need it done as the car is still on it's original clutch at 140k miles .......
if it is the dmf, then you may as well replace the clutch at the same time, as the transmission will have to come out/dropped anyway.
Nimrod
PostPosted: Mon Jul 17, 2017 7:47 pm    Post subject: Reply with quote
I had problems with my c2s diff and gearbox which made 1st to 2nd very tricky.
The diff was replaced under warranty and I choose to have a gearbox rebuild and fit RSS engine mounts and a LWF at the same time. A full rebuild wont be cheap. I had all the bearing replaced and new synchro's from reverse to forth. From memory the parts were about 3.5K including flywheel and clutch and I paid about 2K for labour as the dealer did it at cost.
All in it made a huge difference to the car and even with slightly higher viscosity transmission oil after 5 mins it was a lovely box . The upgraded mounts helped the gear change and I loved the LWF the car was much more responsive and it stops chattering at about 2000rpm BUT it is much easier to stall . Even after 5K miles driving and getting reasonably competent at driving it I would still stall occasionally . I have a LWF fitted in my 997 I enjoy it in the 993 that much, it is actually much noisier but the smarter ECU mean it is far less easy to stall thank god lol.
GT4
993 c4s Artic silver Boxster red
997.2 c4s pdk Guards .
997.1 c2s Hartech rebuild LWF RSS mounts sold .
996 c4s Hartech rebuild- sold
993 C2s TorB HID,Dansk 100 Cell Cat, Rss Mounts, PS10's, LWF and GT3 clutch - sold and still missed.
