997 : 2004- 64
964 : 1989-1993 4
Boxster : 1997- 19
Cayman : 2005- 10
Cayenne : 2003- 4
Macan : 2014- 1
bertyw
PostPosted: Mon Sep 16, 2013 8:53 pm    Post subject: Reply with quote
I happened to have some micro female sockets that fitted over the switch pins, used in miniature radio control plugs and sockets. Used just two wires from each side of the remote switch and connected to pins 1 & 2 works a treat. If you don't want to break the plastic and expose the pins in the switch then a trip to your local model shop may find these sockets or a small length of fine copper tube would slip over them, get some insulation as they are very close if using pins 1 & 2.
Maxie
Yas Marina
PostPosted: Mon Mar 24, 2014 4:27 pm    Post subject: Reply with quote
Chaps - sorry to raise this issue again. Are you literally stuffing the innards of the remote control into the over-head compartment with the wiring soldiered to the Porsche Homelink button?
~ Maxie Question
markiii
PostPosted: Mon Mar 24, 2014 9:11 pm    Post subject: Reply with quote
Exactly that
2006 997 Targa 4S Midnight Blue
1979 928 Mocha Shwarz
Clanky
2007 Porsche 997 Turbo
PostPosted: Mon Mar 24, 2014 10:10 pm    Post subject: Reply with quote
As above, yes. I found there was enough space over the drivers side roof liner.
If you don't fit the original cover over it again before fitting, I suggest you get a sleeve of large heat shrink & put that over the PCB in order to avoid any live terminals touching anything.
996 C4s (Gone)
997 Turbo
S3 Daily Driver
Gollom122
PostPosted: Thu Mar 27, 2014 2:47 pm    Post subject: Reply with quote
rather than soldering to the switch suggest you use a connector - you can get from a model shop or your old PC CD/DVD drive connector will do. That way easier to install in the roof lining.
Maxie
Yas Marina
PostPosted: Thu Mar 27, 2014 5:05 pm    Post subject: Reply with quote
Cheers chaps for the additional info.
Gollom122 wrote:
rather than soldering to the switch suggest you use a connector - you can get from a model shop. That way easier to install in the roof lining.
Thanks Gollum. Will Maplin do those? How would it be easier anyway?
~ Maxie
Gollom122
PostPosted: Sun Mar 30, 2014 1:45 pm    Post subject: Reply with quote
If / when you need to replace the battery in the remote, being able to uncouple without removing the switch will help.
Yes Maplin should do it
 Filesize:  32.44 KB
 Viewed:  3296 Time(s)
markiii
PostPosted: Mon Sep 08, 2014 5:52 pm    Post subject: Reply with quote
chaps I have a spare Homelink button for sale
see here
http://www.911uk.com/viewtopic.php?p=997970#997970
for anyone interested in this mod
Gollom122
PostPosted: Tue May 02, 2017 1:43 pm    Post subject: Reply with quote
DIY homelink and Gliderol remote in the for sale section if anyone interested.
Details in this thread.
RJKflyer
PostPosted: Tue May 09, 2017 6:45 am    Post subject: Reply with quote
markiii wrote:
Do we know what pin3 does?
Might it be switch illumination from sidelight circuit?
997.2 turbo PDK
mkoenigsheim
PostPosted: Tue May 16, 2017 9:52 am    Post subject: Reply with quote
Post deleted.. stupid question..
Gollom122
PostPosted: Thu May 18, 2017 12:59 pm    Post subject: Reply with quote
When used with Porsche Homelink pin 3 is illumination of switch when headlights powered on
Goto page Previous  1, 2, 3, 4, 5
Page 5 of 5
