991 : 2011- 19
997 : 2004- 80
996 : 1997-2005 33
Boxster : 1997- 25
Cayman : 2005- 16
Jamesyg
PostPosted: Thu Apr 06, 2017 11:58 am    Post subject: 996TT - Harness Fitting Reply with quote
I know this is a GT forum - but I figured the questions were more likely to be answered here, then the 996 forum.
I'm just in the process of having a techquipment rollbar installed in my 996TT, and will be looking at installing harnesses next. Intention is to increase track useage.
I've got GT3 replica seats installed, on heavy duty seat brackets.
My question is - what harnesses should I buy, and how should I fit them? - specifically the lap belts.
Given I don't have the GT3 fitting points, the GT3 belts don't seem appropriate. Would I be better purchasing the following and buying a harness with lap belts that clip?
http://www.design911.co.uk/fu/prod128500/Rennline-Harness-Mount---Door-Side-Porsche-911-964-993-996-997-944-928-914/
http://www.design911.co.uk/fu/prod128499/Rennline-Harness-Mount---Tunnel-Side---Short-Porsche-911-964-993-996-997-944-928-914/
Question then is - with the cage installed through the seatbelt point - can I still fit the door side harness mount?
The rest is straight forward - but I can't seem to get my head around those points!
Thanks Guys
‘84 73 RS Recreation
‘83 911 SC
‘79 1500 MG Midget
Pip1968
PostPosted: Tue Apr 18, 2017 6:32 am    Post subject: Reply with quote
I too have the Techquipment half cage. With this fitted you should be able to stick with the OEM seatbelts which still utilize the normal fixing points along with the cage being fixed here. Then the usu Schroth six points can be installed alongside the OEM belts.
A poor picture straight from Google hopefully shows the end result.
Pip
 Filesize:  49.4 KB
 Viewed:  1801 Time(s)
