997 : 2004- 67
996 : 1997-2005 43
993 : 1993-1998 9
964 : 1989-1993 7
Carrera SC : 1977-1983 0
Early 911 : 1964-1977 2
Classic : 1950-1965 1
Boxster : 1997- 15
Cayman : 2005- 16
Cayenne : 2003- 9
912-914-924-928-944-968 4
Paint Protection & Body Wrapping
lofi
2001 Porsche 996 Turbo
PostPosted: Wed Jan 11, 2017 6:13 pm    Post subject: Reply with quote
I'm having a little cry now Sad Wish I'd kept my shed and spent the time and money on it. Boo Hoo Hoo Hooo. They do look so cool and they are a hoot to drive
LoFi
996 turbo tip
ex 944 2.5 manual
ex 964 C4 manual
igaffz
PostPosted: Thu Jan 12, 2017 12:06 am    Post subject: Reply with quote
^ looks grand on the cookie cutters!
Gaz, remind me about the piston angle again?
I'll check on the water pump make, it was £150 from ECP, got it for £100 using the Xmas discount code, don't know how good it'll be but it has the metal impella.
Horizon blue, 964 carrera 2 tip, lowered on koni's, k&n, de-cat, cup pipe, leather trim and 18" 3 piece split rims.
Silver 928 S2, B reg, manual.
Guards red 944 lux, the new project!
Gazc2
PostPosted: Thu Jan 12, 2017 9:18 am    Post subject: Reply with quote
Ian,
if you open the link there is a good explanation of how the piston has to sit at a certain angle relative to the cut out on the top of the piston
2007 997 Turbo & 924s in progress
1990 964 C2
1989 3.2 targa
1987 3.2 Cab
1986 3.3 Turbo
 Filesize:  129.06 KB
 Viewed:  2682 Time(s)
igaffz
PostPosted: Sat Jan 14, 2017 9:12 pm    Post subject: Reply with quote
Got everything back together and filled up with coolant. To be honest I wasn't expecting the very bad vibration at idle to be eradicated fully as I've had a couple in the past with the same simptoms.
Well I'm very happy to report she idles like a rock now with vertually no vibration. I think the problem lies with the balance belt sprockets. To simplify things if the bottom sprocket is fitted the same as the top sprocket it will be 180 degrees out of balance. The top sprocket is fitted with the 'o' mark to the top and the bottom sprocket with the '0' fitted to the bottom.
Back together
The wipers have always been painfully slow so I removed the wiper motor. This was very easy to remove, took me about 5 mins.
I stripped the motor and gave it a good clean and lubricated the moving parts. They work perfectly now so bring it on rain!
I noticed a bit of oil in the air filter box so after a bit of research it seem the seals have gone on the AOS, air oil separator. Luckily this is a cheap easy fix but it's located under the inlet manifold so I'm going to have to remove it for access. I think I'll let the weather warm up a bit befor I sort this
thumbsup
igaffz
PostPosted: Mon Jan 16, 2017 8:15 am    Post subject: Reply with quote
Gaz, I moved the car yesterday when she was really cold and I've still got a bit of vibration but only for around a minuite or less then she quickly calms down and idles really well. Might be old age plus I haven't got the boot carpet fitted so that might be a factor, anyway I might just have to live with it. I'll keep you informed.
Still a million times better than it was though.
Gazc2
PostPosted: Mon Jan 16, 2017 10:34 am    Post subject: Reply with quote
Good stuff Ian I cant keep up with you at the minute jumping from car to car !I have also got a new pair of engine mounts to put on although like yours didn't think the old ones looked to bad,at the end of the day its a 30 year old motor you could chuck a heap of money at it to resolve every little niggle think I`m up to about a grand on bits and pieces which does include new seats and front suspension to be fair its sounds as though you have got it running sweet enough.
1990 964 C2
1989 3.2 targa
1987 3.2 Cab
1986 3.3 Turbo
igaffz
PostPosted: Wed Mar 01, 2017 11:11 pm    Post subject: Reply with quote
Ok quick update to keep everything up to date!
Every time I start this car the heater blower squeaks like a mouse, it's very annoying!
So I removed the plastic cover and removed this -
From hear -
A bit of oil and a clean and it's nice and quiet now.
Next I removed and refurbed the rear brakes, cleaned with a wire brush in the drill and given a coat of cure rust then a good few coats of black gloss hammeright. Put back together with new seals and dust covers, good as new.
Looking sad.
Cleaned up and ready to go back together.
Replaced the rear anti roll rubbers and brackets.
Snapped on though!
Tried to weld a nut onto the snapped stud but failed so I ended up drilling the bolt out and used a new nut and bolt instead. Messed around with the welder for about an hour and ended up drilling it out in about 5 mins! It's always the easy things that waste all your time frustrated
Made up a little petrol bath to clean all the oil out of the air oil separator and pipes. Replaced seals and put it all back together.
Gave the throttle body a good clean aswel.
After doing the belts a had a noise like one of the belts rubbing on the cover when I pressed the accelerator. I ended up removing the cover and tightening up the ballance belt slightly. That seems to have sorted the noise and the engine vibrations at idle touch wood!
Been waiting for my GAZ coil overs for 6 weeks now, hopefully they'll be on there way soon Confused
bye
KP964
Watkins Glen
PostPosted: Thu Mar 02, 2017 12:10 pm    Post subject: Reply with quote
I like a clean throttle body Ian Surprised .... keep up the good work , I'm going to jet wash my engine at the weekend Thumb
Stone Grey Metallic 964 C4
Guards Red 964 C4 sold
Chief
PostPosted: Thu Mar 02, 2017 1:36 pm    Post subject: Reply with quote
Looking good Ian, but couldn't you treat yourself to some new bleed nipples puh
Keith,
DO NOT jetwash your engine! PLEASE......they don't like getting real wet.
- 964 C2 The Red Baron - 914 2.0 Project Blue Book - Cayman S Sport Edition Amber Alert! -
KP964
Watkins Glen
PostPosted: Thu Mar 02, 2017 3:01 pm    Post subject: Reply with quote
Keith,
Any recommendations then Chief ? , I did my red car covering the distributor and air intake blasting low down with the nozzle and it was ok , the thing that worries me is some electrical cables (The sleeves) are open ended and water in them isn't good either !... ive been on a long drive up to Aberdeen and the engine is noticeable salty, the rest of the car has had a major clean just want to sort the engine bay , steam ??? Thumb sorry for the hijack Ian
Chief
PostPosted: Thu Mar 02, 2017 6:28 pm    Post subject: Reply with quote
Kieth,
To me it's a bit like 'Don't put anything in your ear smaller than your elbow'
I would suggest WD40 and a cloth. For the oily bits underneath I use a squirt of brake cleaner and a cloth......
Ian, sorry for the hijack bye
igaffz
PostPosted: Thu Mar 02, 2017 7:25 pm    Post subject: Reply with quote
Chief, unlike you I can stick to a budget, I calculated two new nipples would push the spend to high!
There was someone in America selling a full steel flared arch kit cut off another 914 for $250 and $100 shipping, seemed like a good deal?
Keith, stop farting about and just reverse into the Tyne, that'll rinse the salt off! I'm sure it'll be fine Thumb
deutschland-dobson
PostPosted: Thu Mar 02, 2017 7:51 pm    Post subject: Reply with quote
KP964 wrote:
Keith,
Keith - get yourself some spray on degreaser (like autoglym engine cleaner) and some brushes (not your painting ones!) and cloths. It'll do the job Smile
Ian - cracking work sorting those jobs. I'm off for a petrol bath myself...
Chris
Porsche 911 (964) C4 - Project RED - Outlaw4
Guards Red & Linen, Custom Leather, BBS LM Split-rims, H&R Coilovers, Cleaned Bodywork, 90s audio instal...
Frenchmeister
2004 Porsche 997 Carrera 2S
PostPosted: Thu Mar 02, 2017 7:58 pm    Post subject: Reply with quote
Good stuff Ian, looking forward to seeing it, 944's Rock, I have had one of some description in my life for the past 20 years Thumb
997 Carrera 2S 54 Arctic Silver
944 Turbo S 88 Solid Black
BMW X3 2.0D M Sport 06 Silver Grey
BMW E46 330i touring M Sport 05 Imola Red 2
igaffz
PostPosted: Mon Mar 20, 2017 12:33 am    Post subject: Reply with quote
Another update, I've been grabbing every spare minuite to either fix something or remove something on the car over the last two weekends.
First thing was to strip out all of this nonsense! Some sort of old alarm.
Then I painted the servo, it was really tatty but cleaned up ok, with it painted I could refit everything, fill with fluid and bleed the brakes. It's good to have brakes, when I put it down the side of the house I keep reaching down the wrong side for the handbrake!
At long last the new Gaz suspension turned up.
Rears are a bit of an improvement!
Fronts are coilovers but they haven't got the brackets for the sensor and brake hose! Not happy about it but looks like I'm going to have to get inventive with the cable ties.
Oh and got a bit bored and stripped everything off it, I have to say it practically fell apart compared to the 928! I bet I got everything off the 944 in one shift, I think the only problem I had was with the retaining screws for the front side lights and indicators.
In the above picture you can see the rot! It's only got issues on this rear quarter, the rest of the car is tottaly as new metal wise!
New metal will be made to repair this.
I have a good rear quarter from a donor car to completely replace this
And this!
I'm not a 100% sure why it's gone so bad around the light? Maybe the light has beeen leaking, it was glued in with really hard sealer of some sort, even the little nut that hold the light in were rusty, other sides perfect. Anyway it'll all be cut out thumbsup
It's nearly there mechanically, off the top of my head I just need to replace the fuel lines, replace the output drive shaft seals on the gearbox as they both seem to be leaking and change the gear box oil. Mostly cosmetic after that lol.
Chief
PostPosted: Mon Mar 20, 2017 1:29 pm    Post subject: Reply with quote
Sterling work as always Ian Bandit
My mom had a few of these back in the day and one had the same corrosion as you've seen. I actually remember seeing water moving around in the light cluster. Strange it didn't blow any bulbs Dont know I think it was down to the foam seal.....
Anyhoo, keep up the good work. I think there are a small group of us here that are keepin the brand alive Cool
igaffz
PostPosted: Tue Mar 21, 2017 10:31 pm    Post subject: Reply with quote
There was water in the light actually. I have to add, I've never removed the sun roof from either of the 924 and 944's I've had in the past. Turns out it couldn't be easier! Roll on summer Thumb
KP964
Watkins Glen
PostPosted: Tue Mar 21, 2017 10:38 pm    Post subject: Reply with quote
I though the summer might have arrived early but the gritters were out tonight , car is coming on Ian Thumb
Porschekit
PostPosted: Wed Mar 22, 2017 9:53 am    Post subject: Reply with quote
Ian, fantastic work as usual....I know where to come when I need some advice, make sure you swot up on the 997.1 handbooks Grin
Anyway you might be in for a chance at Ed China's job on Wheeler Dealers since I heard he's leaving the show.....
igaffz
PostPosted: Tue May 30, 2017 9:16 pm    Post subject: Reply with quote
Little update.
Door mouldings removed.
Windscreen has been cut out and is just sitting in place, rust around the screen has been rubbed back and treated with cure rust.
Radio aerial plated and welded up.
Side indicators plated and welded up.
Rear bumper drilled for speed!
bye
Goto page Previous  1, 2, 3  Next
Page 2 of 3
