I would love some but finding the right spec is hard, all the Golf boys have snapped them up
Annoyingly, about a year before getting the 964, a close mate had a set which he sold for £650 with perfect tyres and 18". Had no use for them back then and sold for well under what they were worth.
c:
The novelty of the RS has worn off a bit now so I'm back to working on the cars. Yesterday I thought I would tackle the job of replacing the weaping PAS return pipe. I under estimated this, in my mind, I thought I would simply be able to get under the car and simply pull pipe out once undone.. If I were to write instructions after the whole experience, I would still write that but I would need to add loads of swear words in the middle. What a pig of a job it turned out to be but it's 90% of the way done at the time of typing this.
I'm sure the OPC way of removing this pipe would be to remove the rear trailing arm and ARB but I managed to get the pipe out by just undoing the shock mount to give a few extra mm's of much needed clearance.
So, this is the shiny new pipe from Porsche. Judging by the bag. it looks like it's sat around for many many years but the pipe itself is pristine and in perfect shape.
Hard to tell the leak from the wax sealent that's been sprayed everywhere but the pipe has a tiny tiny hole from sitting inside this little rubber bracket and when the system is working, i.e under pressure from steering, it weaps out and eventually drips.
First thing was to get the car in the air and I set about removing a metal under tray that covers the tunnel area in the centre of the car. Removing this exposes some lines, throttle cable and base of shifter.
I'm sure this had never been removed before and it was completed welded in place!
Undid the hose I was replacing and let the fluid drip into a catch tank. The fluid was black with a hint of red. I believe that this is ATF as opposed to PAS fluid. I have read that I should use Pentosin CHF11S but some say just refill with ATF Dextron 2 or 3... I have yet to refill so I will probably ask a question to fellow UK 964's rather than go off of the 10 year old Rennlist forum posts that are very varied in opinion.
No pictures happened for about 3 hours of wrestling with the bloody pipe. I could have cut it and pulled it out but I wanted to pull it out in one piece to make sure that I could get the new one in.. If I couldn't pull it out in 1 piece, then I wouldn't be able to slot the new one in
Logic!
So as I couldn't find any DIY guides for this at all, I was well and truly on my own and learning as I went, I try to do things in the easiest way possible and try and not disturb bolts that I don't need to but as my patience was wearing thin, my ideas were growing and undoing the rear trailing arm was becoming a reality, something I reallyyyyyyyyyyyyy didn't want to do. I took a break and had a coffee, wiped the dirt out of my hair and face and thought I'd give it one more go, it's a case of twisting and pulling and finding an angle that works, well, within 1 minute of taking that break, it popped out!! Woohooo!!
Pictures resumed
Although 2 pieces here as I took pride in showing it who was boss by snapping the bloody thing where the hole was.
A better view of the rust
i find it straight how it has rusted considering the rest of the car is rust free, this is now the last of the rusty pipes, it was only ever this and an engine oil return that were rusty and everything is perfect. Strange.
Refit time, I was expecting to have similar trouble, but the new pipe popped into place with ease, it was a bit tricky pointed the engine bay side up, I kept getting it caught up with the rear shock and having it go up inside the turret but after a little wiggle, it went where it needed to.
A simple job of popping all of the support brackets in place, new jubilee clips at both ends, centre tunnel cover refitted, rear shock and wheel bolted back on and that was me done for the day.
If you find yourself having to do this job, good luck, it's a ball ache, especially laying on a floor, a 4 poster and you'll have an easier life.
Feel very happy that it is complete, I just need to decide on a fluid and then bleed. :thumb:
Boring update I know, sorry.
My rear shock adapters are on the way from the US so once those arrive and I get some newer style rear top mount rubbers, I'll be able to drop the rear end by fitting the coilovers finally.
Must get around to send Tore my CCU now, leather clean up and OPC service and then that's my to do list for this complete
Until next time! :bye:
