After 25 years there was very little evidence they had ever existed apart from some rusty hard to remove clips. A common issue apparently and you have to look hard to see where they (used to) live, the clips push into the door skin and the strip is hidden under the outer window rubber. A fiddly little job. Part numbers 901 531 935 02 & 901 531 936 01.
