Massive brake squeal - its driving me nuts. :sad:
Inspected the front pads which appear to be Pagid, however only one damping plate fitted per pad (ie one missing). Lots of meat left on the pads.
Inspected the rear which are Textar and have approx 5mm with no damping plates fitted.
I'm assuming its the missing damping plates which is causing the problem - but it could also be the choice of pads? I can't isolate the noise down to a particular wheel - it just seems to be coming from everywhere. Tried but my other half couldn't run alongside to 20 mph or so to listen & find out. :dont know:
Aiming to replace all the dampers and rear pads. Does anyone have any experience of brake squeal and recommendations for brake Pads? Not interested in tracking - just road use.
Thanks...
Thanks...
