991 : 2011- 19
997 : 2004- 77
996 : 1997-2005 35
993 : 1993-1998 7
Cayman : 2005- 16
Cayenne : 2003- 4
PostPosted: Thu May 14, 2015 9:30 am    Post subject: Ticking over like a bag o' spanners - Fixed Reply with quote
Just recently my car's started ticking over bad, i.e. hovering around 600rpm and fluctuating. Also, when stopping and depressing the clutch revs drop really low, car nearly stalls and then gets a blip up to about 1500rpm then drops to being erratic and low again.
Points observed:
Car is eGas so no ICV.
Throttle body and MAF have been cleaned - no effect.
Car only does it after fully up to temperature (say after about 15 - 20 minutes driving).
Runs perfectly normal (around 800-900rpm) at tickover before fully warmed up.
Seems to be deteriorating as time is going on.
Any help appreciated.
JohnnyDangerous
PostPosted: Thu May 14, 2015 9:44 am    Post subject: Reply with quote
Silly question but have you seen lugged into a dura metric? Also check for air leaks
I came into this world screaming and covered in somebody elses blood! I have no problem leaving the same way!!!
PostPosted: Thu May 14, 2015 9:46 am    Post subject: Reply with quote
Had a quick check for air leaks and not found anything (although not convinced there isn't any) and not plugged in for codes either.
Will do if I can't find something myself.
I was wondering if I've not got the plenum back on right when I did my started motor last month. Might take it off and redo it.
Edit: I'm starting to think either airleak or AOS on it's way out.
JohnnyDangerous
PostPosted: Thu May 14, 2015 9:49 am    Post subject: Reply with quote
Easy way to find air leak is with eSy start! Spray sparingly near wher you suspect and see if revs change, have a fire extinguisher handy just in case
PostPosted: Thu May 14, 2015 9:50 am    Post subject: Reply with quote
Laughing
Ok will do.
Neil_Ireland
PostPosted: Thu May 14, 2015 12:58 pm    Post subject: Reply with quote
Mine had those symptoms and it was a faulty oil seperator.
It was faulty new from Porsche, mines a non egas car though.
PostPosted: Thu May 14, 2015 1:39 pm    Post subject: Reply with quote
I'm guessing AOS as it does seem to be progressively worsening which suggests to me a worn part.
rottenbend
1997 Porsche 993 Carrera 2S
PostPosted: Thu May 14, 2015 2:15 pm    Post subject: Reply with quote
Isn't there a fairly easy test for AOS? Something to do with removing the oil filler cap while the engine is running?
1997 993 Carrera S
PostPosted: Thu May 14, 2015 2:24 pm    Post subject: Reply with quote
Yeah but that's only if it's proper goosed isn't it? Dont know
There's a vac on the oil filler but not so you can't easily take the cap off.
I know infrasilver mentioned on another post about testing it but didn't say how.
wasz
1999 Porsche 996 Carrera 2
PostPosted: Mon May 18, 2015 1:13 pm    Post subject: Reply with quote
I'd gamble on an air leak too. Pull the codes - might be "enrichment limit reached". As said spray some easy start around all the joints.
Check the AOS rubber bellows where it connects to the block. Can be hard to tell what vacuum is correct from the filler cap.
You can do this just by removing the passenger side rear wheel. feel around for a split. You can just about replace it too, but I had to use jubilee clips rather than the original spring clips.
Mine was split.
£6+VAT +del http://www.design911.co.uk/fu/prod6696/Oil-Seperator-Boot-Porsche-996-34L-1998-02---Boxster-986-99610723752/
EDIT: Guide here: http://911uk.com/viewtopic.php?t=61942
PostPosted: Mon May 18, 2015 1:47 pm    Post subject: Reply with quote
Great stuff - leave it with me. I also think my coil packs are on their last legs as there's a few other tell tale signs they're on their way out
Can't check anything at the moment as I've just took my car in for a front bumper respray.
Benji1975
PostPosted: Mon May 18, 2015 8:58 pm    Post subject: Reply with quote
Hopefully nothing major Alex...surprised you don't have a code reader...they are an absolute god send. Even if they aren't always accurate, they give major clue's as to which area the problem might be in.
That said, my 20 quid one i bought way before the porker told me that my coil pack/plug on number 6 was duff...saved much faffage!
Ben
PostPosted: Mon May 18, 2015 9:04 pm    Post subject: Reply with quote
I have got a code reader (cheap thing) but no codes have come up.
PostPosted: Mon May 18, 2015 9:35 pm    Post subject: Reply with quote
Lambda O2 sensor would be my guess Dont know Normally when cold there are no signs but once engine starts to get up to temperature it will kangaroo/judder/fart/oldmans knackers on a vibrating exercise plate etc what
JohnnyDangerous
PostPosted: Mon May 18, 2015 9:47 pm    Post subject: Reply with quote
Air leak.................................still Cool
pancobalt
PostPosted: Tue May 19, 2015 5:37 pm    Post subject: Reply with quote
Excessive oil in my 997.1 inlet manifold was indicative of aos that let go.
systemmeister
PostPosted: Tue May 19, 2015 11:33 pm    Post subject: Reply with quote
Is it lumpy as a cement mixer?
I had similar symptoms but mine was vario cam solenoid.
Built, Not Bought......
PostPosted: Wed May 20, 2015 7:39 am    Post subject: Reply with quote
No not that bad. Just when it's right up at temp, tickover is about 600rpm and fluctuating (bad enough to make the clutch thrust-bearing rattle slightly though).
systemmeister
PostPosted: Wed May 20, 2015 7:58 am    Post subject: Reply with quote
Yup exactly same as mine by sound of it.
I will know if new solenoids have cured it shortly.
Putting aircon on raises the rpm and makes symptoms improve?
PostPosted: Wed May 20, 2015 8:12 am    Post subject: Reply with quote
Yeah, but I'd have expected that anyway cos it raises it when it's running fine.
Goto page 1, 2, 3, 4, 5, 6  Next
Page 1 of 6
