evo360 said:ladadida said:I have just bought a C4S a few weeks ago knowing the original OEM exhaust needs replacing. One side has cracked and is blowing.
I am interested what you think about the Topgear switchable system.
When I was looking I was ideally after a car with PSE, but settled on this one with the standard OEM exhaust as the rest of the car seemed good. The Topgear switchable looks like a good solution for me.
I am scared of getting one that's too quiet, or equally too agressively loud if I get non switchable!
So I was in the same position as you. I need it to be quiet when we go away for weekends etc but more open for my more spirited North Wales runs. This seemed to be the best solution from a cost perspective. I have the exhaust fitted however I haven't plumbed in the vac hoses yet so its wide open. I went away for a couple of days in it last weekend and as a daily driver it is too loud, around the 3000k mark it gets boomy, up hills etc under load it's horrible whilst wide open.
I'll report back after the plumbing is installed this weekend and I can switch between. Right now, if I had to choose between a stock set up and this system in a fixed open position, I'd be going stock and looking for some intake noise instead. Hope this all makes sense and I'll respond again in a couple of days
evo360 said:Hi all, just a quick update on the valved exhaust. So I had the car booked into OCD Porsche in Wallasey for a clutch today, I have a list as long as my arm for work that needs to be done, but first things first. Chris took the car and sorted the clutch, he then took a look at the non-opening/closing exhaust. It turns out that I had a split in one of the vac pipes and I'd fitting one in the wrong place. Anyway, all sorted and I can report that with the valves closed, the system sounds completely stock. I am super happy as my weekends out with the wife will be a lot more civilised. Those days in Wales I can open it up and have some fun. Big thanks to Chris at OCD for sorting it
