infrasilver
Moderator
- Joined
- 4 Oct 2010
- Messages
- 9,934
I have had an issue for a couple of months where the outside temp on the dash is very low -38 up to -2 and is continuously fluctuating between the two even though it has been +5 to +13 degrees outside recently.
I have lived with it but a couple of weeks ago I ordered a new temp sender and fitted it yesterday but unfortunately that didn't cure the problem, I am still getting the same very low dash readings. I've checked the wiring to the plug and that all looks fine, so I am now wondering if the plug itself that the temp sender goes into may be at fault or worse it could be a dash issue?
Anyone had a similar issue and what was the cure or are there any tests I can perform?
