thesmithsUK
Nurburgring
- Joined
- 7 Dec 2014
- Messages
- 385
Hi all,
The speedometer and rear spoiler on my 91MY 964 C4 suddenly stopped working today. (The rear spoiler light says on.)
I understand that 'On the 1991 model, the signal comes in from the ABS unit as fed from the LF wheel sensor. It goes to R52, the Frequency Control Unit and also to R24 if you have a Carrera 4, then to the speedometer. The purpose of the FCU is to produce a square wave output using a device such as an ITT UAF 2115. The output of this integrated circuit is used to clean up the pulses from the ABS sensor'.
My guess is that the Frequency Modulator control unit on the relay board may need replacing.
Or could the fault be with the speed sensor?
Is there a way to diagnose the fault, either way?
