bazhart
- Joined
- 20 May 2009
- Messages
- 1,343
Just to make a plea for anyone with experience of a Gen 2 bore scoring failure to assist our research by contacting us.
We have now received a damaged car, engine parts and feed back from a few UK based specialists that has been extremely helpful (thank you guys!). We have measured all the parts and analysed the failure causes with 3.8 Gen 2 engines.
At this stage we don't know how many are likely to be affected - probably less numbers than Gen 1 and probably at higher mileages.
What makes it difficult to assess is the small numbers - yet we hear of a lot more engines being replaced (rather like the early stages of Gen 1 problems).
The Gen 1 was relatively easy to analyse - weaker thin cylinder material with larger forces on it leading to cracking, changes to piston coatings being less resistant to wear, a bearing system that was often inadequate.
The Gen 2 is far better made - should be almost bullet proof - yet there seems to be one technical area of concern.
Problems that relate in some way to the number of complete thermal cycles the engine goes through (probably regardless of mileage) and impossible for manufacturers to reproduce since it require a full heat to fully cold cycle to be reproduced "x" number of times with a lot of sample vehicles - so if and when it occurs - it is often too late to alter the production or find a sensible solution for from them.
It would help me enormously - not so much to find the cause (as I am certain I understand that) but work out the numbers and predict the ages and mileages if anyone who has had any experience of a failure World-Wide - would send me the following information.
(1) Where did the piston score (one side or both sides and in the centre of the piston thrust face or either side?).
(2) What age was the car?
(3) What mileage di it occur at?
(4) Which bank did it occur on?
(5) which cylinder failed?
(6) what capacity was the engine?
This request is absolutely not scare mongering nor seeking business - because we are going to provide a solution in any case as we believe there will be a small but steady stream of similar failures over time. We are also working at capacity anyway and numbers of M96/7 Gen 1 engines are not diminishing.
It would help if those who cannot wait to deflect my simple request and turn it into some other issue kindly leave this particular post for serious and reliable answers - they will not make any car score a bore - but they will help speed up the provision of a solution and minimise the cost for anyone who does experience it - however few that will turn out to be.
Thanks,
Baz
Thanks,
Baz
