I swapped my standard 996 gear selector to the Tequipment short shifter a few years back after winning one on Ebay for just £30.
Massive improvement over stock but when fitted I did just pop the new cables in the same position as the old ones by counting the threads so just relied on them being close enough and though good I do feel the action could be slightly better.
I found on an old post that Porsche sell a small plastic tool that locks the shifter in the neutral position so you just disconnect and reconnect the cables to align them correctly, but also read that this tool is not compatible with the aftermarket short shifters but does anyone know if it's compatible with the Tequipment one?
Seemed worth a punt to just try when the tool was £4 but now it seems to have jumped up to £20 everywhere I look so it would be nice to know if it works before buying than potentially throw money at a tool that won't work for me.
Also I've seen the Tequpment shifter like I have had two versions, either sold with or without the metal shifter bushings, does anyone know if you can purchase these metal bushings separately? I know their are aftermarket ones but I'm a sucker for only fitting Porsche own stuff to my car as I've only had bad experiences with fitting non Porsche parts in the past.
