Afternoon all,
Annoyingly just went to take the car for a spin and the battery is dead.
Could open the doors and all the lights etc worked, but when trying to turn over just got a very rapid clicking and flickering of the dash lights and the window's reacting slightly, the trip meter has also reset itself. It did not even try and turn over effectively.
Obvious culprit is the flat battery but strangely this has been on a CTEK 5.0 charger at all times (via cig lighter as live on the C4s) and as a Bosch S5 (110ah) and only 5 months old that seems strange. The CTEK was showing it at stage 7-8 (i.e. fully charged and maintained) but now plugged back in via the trunk via that connector its back to phase 1 charging which it normally flies past if the battery is in any way charged. I've not used the car in the last 2 weeks through this cold snap but its garaged and should be no issue if the CTEK is doing its job.
So, i'll leave to charge and see if it recovers, anyone else has issue with a CTEK giving false information before I go rushing off to swap the battery under warranty....or could these symptoms point to starter motor (never been particularly slow starting before) :?:
