vlad
Sao Paulo
- Joined
- 16 Aug 2006
- Messages
- 936
Hi, 5 minutes from home got a low coolant warning , stopped and checked and it was low below the min, though water temps. didn't go above the 80.
So drove slowly home, checked underneath and there was a drip, TBH I would normally assumed was the aircon. drain and the patch on the drive is abouts where I'd expect to see a damp path after a run, but perhaps not as central as usual , a bit more over towards the driver side wheel .
However with the low coolant obviously required more investigation, sure enough drips collected had a distinctive pink hue (so coolant?) slightly slippery though? (I couldn't be that unlucky and have leaking power steering fluid also ?) Is coolant slightly slippery ?
I'll be investigating tomorrow, looks like a lot of plastic undertrays to remove first, are there any common failure points?
radiators look undamaged. When the warning came on I feared the worst and that one of the coolant pipes into the engine had come off, but dry as a bone at the back.
Pics are driver side just behind the front wheel.
