Gwsinc said:Code 45 is indeed the fan at the back of the CCU, I've just replaced mine with Tore's version and it makes a big difference. Read this: https://www.bergvillfx.com/categories/964993-ccu-details
As for Code 24 this relates to the fresh air flap servo which I believe middle of 3 servo motors under the cowl. I'm sure Tore will reply soon to confirm as he is active on this board.
Hope you get it all sorted soon
:thumbs:
motivator said:Hi, I have bought the T-OBD diagnostic tool from ToreB, which was easy to install and run, Thanks Tore.
However it has brought up 2 CCU faults
45 inside sensor blower motor
24 fresh air flap motor
Can anyone help with what these actually mean, I am hoping the 45 relates to the small fan behind the CCU sensor which I also bought from ToreB as a precaution?
Can you easily get to the fresh air flap motor and replace it as a part, or is it one of those "whole HVAC cassette out" situations?
