Phil 997 said:
I have also done the gt3 throttle body and plenum upgrade you will need a remap with it so choose you mapper carefully based on rep. Its a very good mod and makes a big difference to the power and way the car breaths and performs, more air in more gas out equals more power, Its the next performance mod to do after the exhaust. Have you already done the induction pipe and BMC filter upgrade. :thumb: :grin:
I'm always a bit skeptical with claims of big improvements on a naturally aspirated engine's power from just induction and exhaust mods.
What I've typically found in the past is that the standard induction on sports cars, despite often looking restrictive, is actually more than adequate even at moderately increased power levels. For example, the tiny airbox on the 290 bhp Evo VIII was retained on the 400 bhp tuner produced Evo VIII FQ-400, i.e. the standard induction could provide enough air for a 40% increase in power.
You find the same with many other forced induction models - puny looking inductions are easily capable of supporting 10%+ more power.
Seems to me that most of the claimed gains from aftermarket induction kits (at least those that aren't completely made up!) are from the kit changing the airflow and tricking the car's air sensor into believing less air is flowing than really is. The ECU therefore leans out the AFR and this is where power gains are obtained - from leaning out the fuel mixture, something that could be done with a remap and leaving the standard induction in place.
My history with fitting aftermarket exhausts to big engined NA cars (4.0L M3, 5.2L S6) is even worse - at best there is no power increase, at worst you actually lose power.
Getting back to fitting the GT3 throttle body, the GT3 engine is chalk and cheese to the 996.1 engine, not just in capacity, but cooling method, materials used and rev limit. I struggle to believe that bolting on one fairly minor part from it can lead to any substantial gains.
